cutting carbon fiber (fibre) http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=15797 |
Author: | SniderMike [ Fri Feb 08, 2008 12:48 pm ] |
Post subject: | cutting carbon fiber (fibre) |
I've got some thin carbon fiber strips that I need to rip. What is the best tool to do this? I've seen cf eat up chisels, so I'm afraid it will ruin a tablesaw or bandsaw blade. Thanks in advance. |
Author: | Jimmy Caldwell [ Fri Feb 08, 2008 1:14 pm ] |
Post subject: | Re: cutting carbon fiber (fibre) |
I have a little table/sled I built for my dremel and use the fiberous discs for blades. It does wear the disc down pretty quickly, but it works. |
Author: | Jim Watts [ Fri Feb 08, 2008 1:40 pm ] |
If they're thin, like .03 or so, you can cut them along length wise using a razor knife and a straight edge. It'll take several passes but it works pretty well. |
Author: | SniderMike [ Fri Feb 08, 2008 1:42 pm ] |
Author: | muthrs [ Fri Feb 08, 2008 2:26 pm ] |
Like Jim said, if it is unidirectional carbon fiber you can pretty much cut it with a knife. I even just carefully snap it in that direction. Just recently I found that tin snips (the ones that look like overgrown scissors) work great for cutting across the fibers. I also use bias carbon fiber where the fibers are laid up on a 45 degree angle for my bridgeplates. In this case I have to cut with tin snips no matter what direction I am cutting. I always clean up my edges by sanding. Don't breath the dust. |
